Fuel Tank conversion to Pick up bed
will.rynerson
Okay,
I’ve purchased a fuel tank to go under the bed of my 1945 Ford 1/2 Ton pick up.
I’m wondering if anybody else has converted from under the seat to the bed of their pick up. I could use some insightful steps. Any information would be greatly helpful and appreciated.
It's quite common and pretty straight forward. Keep in mind, many more people are working on the '48-'52 trucks than there are the '42-'47, so there is more info to be gleaned from checking out what they're doing. Being the frames are nearly identical between these years, the '48-'52 rear tank install will be pertinent to you. Check the interwebs for all the various ways these tanks are being installed.
Good luck!
What tank are you using? I just bought an aluminum 17 gal. 'fuel cell' for my 47 frankentruck. Not sure what makes it a fuel cell instead of a tank, but it was like 214.00 with a sender and thick black exterior coating. That whole area between the frame rails on our trucks makes it pretty easy to do this conversion. I would like to see some photos of your tank and it's brackets and plumbing.
I picked up a tank from EBay 1957-1960 FORD F100 F-100 1/2 TON PICKUP TRUCK ALUMINUM FUEL GAS TANK BED FILL. 265.00
They did not give any instructions. Sooooo I’m not sure what the 2 small hole on the top and are for.
CCP
Steering • Brakes • Suspension Call the Experts
1957-1960 Ford F-100 Aluminum 15-Gallon Fuel Tank
**Our aftermarket in bed fuel tanks bolt to the bottom of the frame in-between the frame rails after the rear axle. Removal of the bed may be necessary for installation**
These aluminum tanks are a must for anyone wanting move the original style tank from behind the seat to under the bed, between the frame rails. The tank comes fully
baffled and is designed to work with a fuel cap on top of the bed for fuel filling. The tank comes with the fuel pick up with a -6AN fitting and an attached steel tube.
A roll over valve is also included - that will stop gas from spilling out if the tank would happen to be upside down. There is also a preset spot for the sending unit and two ports on the bottom of the tank for fuel injection (one of the port can be plugged as well for carburetor applications).
Features:
Aluminum construction
15 gallon capacity
Bed fill design
28.25" wide
16.5” deep
8” tall
32.25" overall width including mounting flanges
Included rollover valve
Two fuel outlets
Requires rear crossmember removal
(Part# AGT-BTANK)
I Guess I know what the holes are for now.
