I'm a neophite but I'll describe my experience. The Barn suggested that my 31 Coupe would not run because there might be "junk" in the shut-off valve. I took it out and, sure enough, it had become completely plugged-up with gunk. I had removed the handle from the valve (not knowing that is not necessary to clean anything out) and removed the packing nut (also unnecessarily). Recognizing my mistake, I put the nut and handle back together. I installed the valve back in the car and, voila, the car ran beautifully. However the handle, which was easy to turn before, was now hard to turn. I think I got the packing nut too tight. Maybe your valve packing nut has moved and caused the handle to become hard to turn. Well, again, I'm a neophite, so check it out, that could be the problem. The good news is that you should be able to make the nut adjustment right in the car. I had to drain all the fuel out of the tank in order to clean the gunk out.
