Look up, VDO Reed Switch Fuel Sender - 150mm - 240-33 Ohm, #226-615.
My 1941 Ford conv. coupe upgraded to 12v fuel sender never ready worked right. Some days better than others. I realized that the sender in my boat would work in the Flathead. Comes pre wired with gasket. Will it work on 6v with a resistor, I don't know. My tank is 6.5: deep > relates to the 150mm.
240-33 ohm for the 12 volt gauge. Check it on the internet. See ya
