Fuel Sediment bowl
DPV1936
I have a 1930 4door with the cast iron sediment bowl. What is the spring for on the drain valve? My car did not have one but I have seen some pictures of cars with and some without. A spring came with the filter/washer rebuild kit. It seems the drain valve needs to be screwed all the way in to not leak but if I install the spring that wont be possible.
The length of the threaded portion of the unscrew part determines whether or not a spring can be fitted. Yours apparently not.
Joe K
