I've moved a lot of gas in my T. That's why I like the open top. But I've never tried to pump any. I'm afraid if I pumped I'd have a horrible mess to clean up.anybody here put an electric fuel pump on a Model T? If so which one did you use? Need to install one on another antique car looking for info.
Thanks
Maybe it would come in handy on a steep hill and save having to run the tank full to get up a steep hill.
Don't have to. We just back up the steep hill..
Keep in mind that early carburetors can handle very little pressure. Most electric fuel pumps made today are 4 psi or higher. Most older cars can handle 1 to 2 psi at the most, so you will also have to buy an adjustable regulator that will go down that low. If you need a 12 volt pump, those are easy to find. 6volt pumps will usually have to be special ordered but a good auto parts store can find one for you. I believe Snyders sells a 6v pump and I think Langs (Langs Old Car Parts, 1-800-872-7871) does as well. Good luck
If you only need it on the steep hills try this idea, it worked great for us. T off the gas line after your shut off valve under the tank. New line goes to fuel pump and then to another T close to the carb inlet. Yes you will be pumping in a circle but there will be higher pressure on the carb end and not so much as to flood the carb. Control the pump with a push switch so the pump only runs when you push the button as needed on steep hills. The rest of the time the flow will be gravity and you cannot " forget" and leave the pump on!
