Thank you. The reason I ask is because that is what I have on my car now. It has never worked well enough to supply fuel without the electric pump running. It will run the engine but it starves at higher speeds. I put a rebuild kit in it without noticeable change. The electric pump I am running is a carter inline from Macs. (See link) Could be a problem with the push rod I suppose. Anyone know the length it should be on my car? I will check length and lift next.
https://www.macsautoparts.com/ford_...and-with-in-line-filter-ford-and-mercury.html
It is the stock aluminum intake for my 37.
I do. I like the glass bowl pumps. It catches debris. Not sure that the fuel pump rod length makes a difference with the glass early pump less you change the intake. or you have a 8ba or pump.
A old wise tale was to use a poker/player card to make a pump gasket to increase pressure, as it was thinner. Might help....
My thinking is if the cam lobe is wore, it's not good. Does that happen?
Thought the rod throw was around a 1/4" +/-. As posted.
