tintoptexan
I am having problems with my fuel pump. The engine is a 1947 model 59AB in a 40 merc convertible. It is dressed out as a 40 except for the distributor and coil. There doesnt seem to be enough throw on the push rod. I checked the length of the push rod and it is as required, 7.87 with an aluminum manifold. Does anyone know what the travel is for the rod? I'm hoping that the lobe on the cam is not worn. The pump does not leak and working it by hand, it will pump with long strokes. Any help will be appreciated. Thanks, Joe
