Ditto on leave it stock. That way, if the electric fuel pump fails, you get home. Just be sure to use an electric fuel pump that does not block flow when it is off. I use Mr. Gasket 42S because it puts out only 3 psi which won't flood a flathead. Mine is 12 volt. Not sure if you can get it for 6 volts.
