M mustang1215 Member Jul 21, 2023 #1 I am putting a new fuel pump in the car and the old one does not come out. could it be stuck in out, pull it harder ED.
C cas3 Well-known member Jul 21, 2023 #3 The pump arm has a small cup on it that the push rod goes into. You need to go up a bit to clear that cup, then it should pull out. What pump did you buy?
dean333 Well-known member Jul 21, 2023 #5 I always remove the fuel pump stand with the pump in one piece. To me it’s easier that way, especially on the reinstall.
