The new one I bought was foreign made and put out 5 psi and now resides on shelf.
Unfortunately, if you measured 10 new currently made pumps no matter who's label was on the box, you would probably get 10 different PSI readings. If yours is too high put in a regulator, if too low, don't use it or try rebuilding it. The valves are probably leaky.
Do you know what PSI it puts out?
Two words (or maybe one) : "Charlie ny"
I agree!!!!!!!!!!!!!!
not the time or place to go over this!! The question was to do with fuel pressure Stromberg did publish a chart that showed how to correct the fuel height according to fuel pressure but for ease of use fit a quality regulator as shimming the pump stand [as touted by some on here ] will also effect the the volume and therefore create another problem
