Fuel pressure
You might want to ask on the early V8 forum. If you are running stock carbs/fuel pump you should not have to.
I have 3.5 pounds of fuel pressure need to bring it down to 2, 2.5for Stromburg 97s . I will repost in V8 sorry
Put in neoprene float valves and you can run 8 lb. if need be. They never leak.
They are impervious to alcohol also.
