Reading this thread because I just replaced the line in my '36 pickup. Nels would you explain "the fuel line needs to be slid into the tank"? I also have a new tank and I just cut the line close to the compression nut as usual and it seems fine. Oh by the way after considerable hunting I found cupronickel line not at an auto parts store (nobody had it) but at a hydraulic supply store in case anyone is looking for local stock.
It (the line) only needed to extend into the tank a short bit. You did it just fine![]()
I just assumed that the female fitting at the tank had a tube running down near the bottom of the tank. Am I mistaken?
Ya know, I can't recall the inside of a tank as I haven't cut one open in decades.
What I do recall clearly are all the tanks I'd removed lines from and never was a line protruding more than a 1/2" or so beyond the fitting.
