Fuel line flare
When I do choose to use any teflon, such as on a rad. hose barb on a modern car like a SBC i get the kind that comes in a tube, and use it very sparingly. The tape can be very troublesome.
Tom Endy has a unique situation of removing the fuel line often because he tests many many carbs
Tom W's way of making a ferrule seal again by tinning on a layer of solder is actually very creative, but soldering is a skill not all have mastered.
But everyone on here is correct: the threads of the brass nut do not account for any sealing at all; so no sealer belongs there
The ferrule seats in two locations; on the gas line and inside the carb. If the seat inside the carb is dirty or miss-shaped fuel will leak around the threads. I use a Dremel bit (911) to clean and reshape the seat.
We replace the one piece ferrule and nuts with loose ferrules and nuts when we sell the tube. The thread for the nut is 1/2-20 not a normal Ace stocked item.
Who would have guessed such a simple task could require over 40 posts. If you must use a joint sealer, google "Gasoila E-Seal". Specifically for E10 and E85 fuels.
If the ferrule is not compressing around the fuel line and into the seat in the carb/fuel bowl and nut, no amount of sealer is going to help. The thread on the nuts is straight not tapered and only holds/compresses the ferrule to make the seal. We clean the seat in the carb/fuel bowl using a ball type, but gets to same place. Those areas need to be clean to seal. More often then not, just needs a light clean to seal.
