Fuel level in Zenith Carb
Colorado kid
I dropped the bowl to check for sediment and wondered what the level should be without the float displacement. The float sits level when inverted. I measured the fuel level which is above the jets which was about 1” to the base. Just curious, I’m trouble shooting which I suspect is my new old style condenser. Seems like every time I take the coupe something goes out, coil, cable switch, whole distributor $$$. Soon GR8 Dane will have a whole new electrical system!
This image is several years old , but red line indicated level with float in place, yellow is the same level without float displacement , and green level (actually just below this line ) when run at idle to engine dying.
The only reliable way to measure the fuel level in the bowl is to use a tube that attaches to the underside of the carb at the drain plug under the main jet. You can do it right on the car. You can even do it on a running engine, if you want to really see how it looks when running.
The fuel level in the bowl when you remove the float is subject to too many uncertainties, like fuel dribbling out of the float valve as you lower the bottom carb casting.
Measure down from the gasket seam between the 2 carb casting halves to the fuel level in the sight gauge tube. Many people will tell you to make it 5/8" down, but it is hard to tell exactly where the gas falls in that tube, and it is better to err on the "lower fuel level" side than higher.
So I aim to set the fuel at more like 11/16" below the seam, and even as low as 23/32". The engine will run just fine at those fuel levels and the uncertainty in the measurement means that the true fuel level is probably higher.
If you aim for 5/8" and end up with it a bit higher than that by accident, the fuel will potentially overflow the tips of the main jets and the carb will drip. That's why I aim for a lower fuel level, to make up for the measurement uncertainty. I don't like my carbs to drip.
That’s the little tube Jim is referring to you.
And he has right — any other measurement is less accurate!
Yes .."..The only reliable way to measure the fuel level in the bowl is to use a tube that attaches to the underside of the carb at the drain plug under the main jet. .... You can even do it on a running engine, if you want to really see how it looks when running. and it is amazing how much it initially drops when you rev it!
Thanks for the advice and info. Maybe a tube in the future once I get all these 100 year old parts replaced/ reconstructed
