maxparplus
I just bought a 1938 Ford Standard and it appears that the fuel gauge wire is disconnected to the tank sending unit. I found a wire in the rear harness but its hot all the time & I'm afraid to connect it to the sending unit. (Remember this is 6 volt positive ground) Do I connect it and have it hot even with the ignition switch off or should I rewire it to switch on only?
Thanks,
Max
Thanks,
Max
