jagnweiner
My 59AB has a mechanical fuel pump with sediment bowl. (It also has a switchable electric pump which I haven't had need to use). When I first got it a few months ago, I had problems with deteriorating fuel line junk filling the sediment bowl and clogging the carb. Cleaning out the bowl and the carb seems to have solved that problem, but I figured it might make sense to have a fuel filter, so I ordered one.
Questions: the pump had a screen and gasket. I ordered a new screen and gasket as well. If I put the filter in, is it in lieu of the screen, or does the screen go in as well? The filter came with a spring, but the sediment bowl has a lip that would hold the filter in place. Do I still use the spring? Finally, if the pump didn't have a filter on it, is there a problem with adding one?
Thanks in advance.
Thanks in advance.
