FSI Spark Plugs: AC Delco R45XLS - HELP
sandbug
I am running Autolite 3076 spark plugs on my Model A
('32 B Engine, high compression head, alternator, 12V, FSI, Headers, Stromberg 97).
I'm getting some pre-ignition knocking, so I am in communication with FSI to adjust the timing.
I decided to get some cooler plugs, so I went onto the FSI site and bought a four-pack of AC Delco R45XLS plugs. It says they are 14mm resistor plugs, better than Champion W16 plugs,and I didn't know the Model A uses a 7/8" thread plug.
My son's '30 Coupe has 7/8" thread plugs, and it's all standard in that area.
Are there any Model A heads with a 14mm plug?
Can I find and add a thread sleeve to make a 14mm plug work?
I've got a call to FSI, but Oklahoma time is different than California.
Standard was the 7/8. 14mm is the more modern plug and also used in many of the aftermarket heads.
I can't understand using a resistor plug in an A. As have no electronics to interfere with. It's also puzzling that FSI says to use resistor plug wires when the stock Model A plug connectors they supply are solid brass.
The resistor plugs and/or resistor plug wires are to reduce RFI, maybe RFI interferes w/the FSI ignition.
That’s what they are concerned about FSI , along with don’t leave it no longer than 30 seconds with the engine not running, and very clean electrical connections
