Roadster Rich
I have had an FS electronic distributor on my Roadster for about 12 years. It is the older one, not the one that resembles the Model A distributor. I had the head off for some work a while ago and reassembled. Timed the distributor with a timing light at 3 degrees advanced at a low idle. But the starter barely turns over the engine. With the switch off it spins fast (normal) but with the switch on it barely gets "over the top". I think this means that the firing is early. But running over the road feels just right and based on the way they say to time it, it is just right. Any ideas?
Probably most of the ideas will be to replace it with the original and in fact I think that I will order the parts to rebuild one of my old ones. May be the time to go back to what I remember.
Rich
Rich
