FS 1930 Model A Xtra cab 4X4 pickup
Sunnybaba
Silver City
NM
Price
15,000
Custom Built, 1930 Model A 4X4 extended cab Pick up truck.... It is Not a Hot rod and Not a Rat rod.... It is a practical... daily driver, Vintage 4X4 truck....:)
I boxed and extended, the frame to be able to mount the 1930 body, which came from a model 170-B 'Blind back' 4 door sedan. All the wooden frame work was rotten, So... I replaced it all with a custom formed, tubular steel framework. I wanted a pickup cab that had abundant leg room ( I'm 6' 4" 200 lbs.) So, I used the back of the sedan and 1/2 of the rear doors & windows to create a extended cab for the pickup. The entire cab and floor are sound proofed and insulated. All new, lightly tinted safety glass installed, with new window channels and regulators... The gas tank, that used to sit in your lap, was removed and a new steel dash with glove box and gauges from the 1983 Toyota 4X4, truck, installed. (pre-computer) New motor and transmission mounts created, and a removable transmission cross member bolted in and three other cross members welded into the lengthened frame.
It has a very low mileage 22R four cylinder engine (105 Hp) A new Weber carb, with manual choke, New 3 core aluminum Radiator installed (never over heats)... New heavy duty clutch/pressure plate, new fuel & water pumps,Timing chain kit, and new alternator & regulator, hoses & belts.... New 6 ply tires, New brake lines & radius rods installed All new leaf springs (front and rear), new coil over shocks (front & rear) spare tire mount installed under pickup bed in the back. rebuilt 5 speed ******, where 5th gear acts as an overdrive, over 50 mph. The 4x4 is a solid front axle, with manual hubs.. and works perfectly. it has power brakes (disc in front, drum in rear) New rack & pinion steering.
The Body was welded, sanded, primed and painted with enamel paint, (Black fenders & dark forest green cab,hood and bed). New headlight lens, reflectors with halogen high & low beams, new tail/brake lights, with led turn signals front & rear. Very comfortable, adjustable, bucket seats, with seat belts. Good strong Heater with windshield defroster. Ahooga horn and new windshield wiper motor and blade. Clear title in my name, licensed & insured as my daily driver... Very dependable & easy to drive. Valued at $15,000 contact, Sunny 505-990-6008 sunnybabaspirit@yaho.com
many more detailed photos upon request Thank you for taking the time to consider this Truck...
I will consider trades for a good running Original, unmolested,... 1929-1934 Sedan ....:rolleyes:
