I need to free up a clutch that sat for a year without being depressed. I took off the cover and greased the throw out bearing. Bearing moves back and forth but Clutch disc does not disengage. Suggestions?
Thank you
Jon
I unfroze a clutch on a car that sat in a field for 5 years. I did as WHN said. Use high gear as the brakes will have a greater effect and it will be less strain on the transmission and rear end.
