Was working on a friend's car (which was running poorly) and noticed that the intake manifold frosted-up when the car was first started. Frost stayed there for quite a while till the engine was good and warm. Thoughts, anyone?
Intake icing doesn't always lead directly to performance issues. Sometimes it's just a byproduct of your ambient temp and humidity. This problem is more common on cars that use an air filter. It may also indicate a poor interface between the intake and exhaust manifolds.
old vw beetles with single barrel carbs always froze up.
i havent had a model a do that. i would guess, like said above, temp and humidity. let it warm up.
edit
is probably why ford bolted it to the exhaust manifold.
