CountrySquire55
Friend of mine has a 29 Fordor which has developed an occasional front wheel wobble when hitting bumps at low speed. Wobble is stopped by bringing the car to almost a complete stop. Does not happen with all bumps but more than 50%. I had the same problem last year with my 31 Slant Town Sedan and found my problem to be loose, worn pitman arm. Replaced pitman arm and my problem solved. Pitman arm is tight on friends 29 Fordor, as are lug nuts, wheel bearing, and (seemingly) all front end linkages, with very little play in king pins/bearing. Any suggestions on what might be causing this wobble problem? Thanks!
