Earle
I'd appreciate some thoughts and expert input from the Gang: I'm wrapping up my list of "periodic service" and maintenance items in getting the roadster ready for spring. I always remove the wheels and drums to inspect and vacuum out the brakes, repack the bearings and add a trace of hi-temp grease on the wedge and rollers. But how tight should the spindle nut be when reinstalling the drums? It's all a matter of how much "preload"or looseness" should be put on the bearings.
I have driven for years on the premise that you never want to "over-tighten" bearings because it squeezes out all the grease as the roller runs on the race, over-loads the bearing and accelertaes over-heating and failure. Overly-loose bearings also fail early from allowing the rollers to lift off the race and undergo cocked, high "point-loading" on the race instead of the intended "line rolling Contact loading". Both lines of reasoning are logical. BUT between "over-tight" and "over-loose" there's a lot of dangerous wiggle room.
Sooooo...I have always hand-tightened the spindle nut while slowly spinning the wheel. Then when it's hand-snug, back off to the nearest castle slot for inserting the cotter pin. Of course you can then sometimes feel a tiny bit of wiggle in the wheel when it's re-installed. I've known others who tighten the nut to the next nut slot - or even an extra slot further!
Here's what got me confused. After getting my car back from Schwalm's recently for some brake work, I found that their mechanic had tightened the spindle nuts so much that I needed a wrench and considerable effort to loosen them. When up on jack stands, the wheels would quickly come to a stop when I tried to give them a good spin by hand. Since Ora's crew are good mechanics, this worried me some and got me thinking about it. What would have happened if I had kept driving it in that extreme condition?! When I called Ora about it, he agreed that was too tight but he does like "tightness" rather than any looseness at all.
We can't talk in terms of a specific nut torque because castel nuts don't allow it - and only a tiny turn of the nut is the difference between tight and loose.
Thoughts?
Thoughts?
