newshirt
I wanted to perform the test below, as described in the Service Bulletins, page 203. But now I have a question: Where should the cold chisel be placed? Does the photo show it in the right place?
Checking Front Wheels for Side Play (Service Bulletins, page 203)
The front wheels should be jacked up periodically and tested for smoothness of running and side play. To determine if there is excessive side play, grasp the sides of the tire and shake the wheel. Do not mistake loose spindle bushings for loose bearings. Insert a cold chisel between spindle and axle when making this test to take up any spindle bushing play.
