`I am a bit uncertain as to the part you are seeking, but if it is the short leaf for the top position on the front spring I can probably help you. Are the ends of your spring leaves square cut or do the leaves have clipped corners at the end? I would match the type you have if possible.
Please reply to Rich at barnstuf@comcast.net.
