Tom Endy
Can someone explain why there are two different outside diameter size shackle bushings for the front spring and perch in the Model A kingdom. A few years ago I rebuilt several Model A front ends. I ordered replacement front shackles from Bratton's. They arrived with bushings that were thin wall and too small in diameter and did not fit the inside diameter of the boss in the spring and the perch.
What was needed was a shackle bushing that was the same outside diameter as the rear spring shackle bushings. What I finally did was order a dozen or so rear shackle bushings from Bratton's and had the length cut down.
The bushings that came with the front shackles were discarded and I used my supply of shortened rear shackles bushings on several front end restorations. The problem was solved.
Currently I am working on two front ends and both require the thin wall bushings in both the spring and the perch. My cut down rear shackle bushing are too large in diameter to fit the spring boss and the perch boss. The diameter of the shackles themselves are the same, it is the inside diameter of the bosses on the spring and the perch that are smaller.
The outside diameter of the thin wall bushings are a nominal 0.690. The outside diameter of the thicker bushings, the ones that are the same outside diameter as the rear shackle bushings, are a nominal 0.753.
What gives, has it something to do with year models?
Tom Endy
Tom Endy
