This is the front end out of a chassis I just picked up. Why are the upper spring leaves square? Were just some replaced? The upper three are even wider. Should I replace the whole spring or is it usable is taken apart and cleaned.
It is hard to 100% sure, but the taper on the longer leaves does not appear to be factory. The seem too short. The taper used by all the known Ford springs is different then all I have seen on era and later aftermarket springs.
