mass A man
I'm spending some time on a '31 town sedan project car I've had for many years now, and found the front spring that came with the car is not a 10 leaf model A front spring. 12 leaves, the top one shows a number/letter designation I'm not familiar with. Maybe some of you all can tell me a couple of things here---What the heck did this come off of, and can I remove the top two leaves, leaving me with what I believe to be a good spring,(with 10 leaves), that will fit the car properly. The numbering on top leaf is; A 5310 B. Measurement from center of each eye is a hair over 30-3/4". From shop floor to top of spring is 8". As I remember, 15 years ago when I took the spring off car, the U-bolt nuts were just jammed up tight as far as they could get them on the U-bolts, cotter pin holes nowhere in sight! Can you imagine this unit coming off while driving!!!
