B B-nut Senior Member Apr 30, 2011 #1 When installing the front spring is there a webbing pad between the top leaf and frame as on later Fords? Thank you guys.
CharlieB Well-known member Apr 30, 2011 #2 2 are presently being sold by T suppliers. An original leather type and a rubber type. I went for the modern rubber.
R rond Member May 1, 2011 #3 The leather type is thicker, and may last longer. The important thing is to use some kind of pad between the spring and crossmember.
