The problem is with rebound after I hit a dip in the road. I have tube type shocks and have bought KYB shocks to replace the ones that came in the kit. It rides reasonably well on smoother roads (DUH!) but I've ridden in stock suspension cars and the ride is much more controlled. The Posie spring is almost flat and I agree with Andy that it contributes to the uncomfortable ride. I don't have a stock spring to measure the main leaf, hence my question on interchangeability. I'm hoping someone can tell me if the '47 spring will/won't work.
I have rebuilt stock shocks for the front. When the weather cools down a bit more I'm tearing the card down to install a rebuilt flathead, hopefully change to a column shift trans, do an engine compt clean-up, etc. and would like to fix the front suspension then.
