In rebuilding the front end of a 1928, I found the original spring was shot. I purchased a new front spring from Snyders. It was the one they list as a show quality spring. I think they source it from A-Springs. Anyway, the total spring set is thicker top to bottom than the original. It fits in the cross member nicely, with the square bolt head up through the cross member, but I cannot get the castle nuts on the front clamp set up his enough by quite a bit to cotter pin it.
The bottom leaf spring shows more than the original did beneath the cross member and measurements confirm the spring is thicker. Short of finding another spring - and this one was expensive - anyone have any ideas on how to make it work so I can get the castle nuts on and pinned?
Thanks in advance!
Thanks in advance!
