Front spring 39 pickup
sunshine
Thanks for any info. .? How many leafs should be in front I have 8 and looks to be weak , the main leaf is not arched at all . I have a 13 leaf spring from a 41 pickup will it work or can I remove some leafs if so which ones. THANk YOU. SUNSHINE
37-39 pass. and comm. used 11 leafs (78 5310-c) or 12 leafs (78 5310-d) for "rough" roads. my 39 tudor had 11 (several broken) and i replaced it with one from my parts car which had 12.
You can re arch the spring yourself. Draw on cardboard the arch needed.
Then bend the spring leaves to match. I did my 39 pick up 25 years ago
and it still sits good. Or a local spring company can do it for you. G.M.
Eleven is correct. It is in my opinion critical to get your hands on (preferably) a NOS spring. Modern replacements are typically not "matched" well to Ford specifications. I might suggest you contact Carpenter's.
Removing a leaf or two from an incorrect spring is not as simple as simply taking one or more away. Each leaf was manufactured to a specific weight / height ratio.
