46ford
I'm "freshening" the engine in my '46. After replacing rod bearings and rings, I'm almost ready to put the pan back up. Gonna install a new oil pump too. Here's the question:
My felpro gasket set came with a larger diameter (short) oil seal which I assume is for the front. Also has two longer, smaller diameter seals which I assume are for the rear, but in order to be long enough they'd need to be placed end to end. The seal I removed (which frankly looks reuseable with a smear of RTV silicone) is a one piece seal. I have used the search function but haven't seen anything regarding the two piece rear seal.
Thanks! The oil pump is coming from California so I have a few days...
