Front mounted tool box?
Kevin - Illinois
I'm debating on installing a front mounted tool box inside my splash apron (which I know covers the crank hole but I'm not worried about that). I'd like to see what the Snyders tool box looks like mounted, does anyone have a pic they could share of it on their A? Also, any homemade version pics are welcome as I'm considering making my own brackets and installing an antique box.
This is a Craftsman box with a lift out tool tray that I painted black. 1/4" X 2" strap bracket bolts to bumper brackets. Took about an hour to fabricate.
I was thinking of fabbing up something to go there, but I want it removable. I am weird enough I likely would want to try using the crank once in awhile.
I don't think that is weird, I like to use the crank now and again, makes folks take notice. It's fun to see the look on folks faces when you do something they never even thought about. Then they start asking questions.....:D
In the Model A Times we reviewed a couple of front mount tool boxes, have you looked at the one from Mike's A Fordable? It doesn't hold as much but looks like it was made to be there.
The crank hole is important to me mostly for making sure the car is timed. Getting that pin to drop in the hole at top dead center. I tinker with my engine a lot though messing with dual carbs and ignition so that may not be necessary as much for others.
I also have seen people fabricate bent wrenches to turn the crank bolt from the side, so perhaps that's the answer.
