In the process of working on my 31 coupe. The front motor mount appears to be missing the arched bar that should be there and who knows what else. I have all the replacement parts but just need to get the yoke off to do it. I don't see anywhere where is says to remove the crankshaft pulley and it seems almost impossible to remove the springs and bolts from the mount with the pulley in place. The radiator is off along with generator etc. (I am also doing a head gasket) How is it done? If I have to remove the crank pulley, can I jack up the engine far enough to get a 1 3/8 socket on the nut? I have read in some old forum posts to remove the rear motor mounts but how far can I jack up the front before those have to be removed. That is if I have to remove the crank pulley at all.
Thanks
Mort
Thanks
Mort
