If you have all the parts in the rear mounts I don't think there should be much give.
With the shoulder on the rubber pad in the frame hole and the metal sleeves through the rubber
there's not much room for movement.
Bob, I do have all of these things in place and I think?? they are in the holes in the frame correctly. At least they were when I first installed the mounts. But I did loosen the nuts on the bolts so I could work the motor mounts around a bit so I could get the engine bolts installed. With the round cylinder things around the bolts, I think those things should keep everything installed correctly.
