I have a 1930 Cabriolet. About 1.1/2 years ago I replaced the Front Float-A-Motor (FAM) parts with new original style front motor mount parts (both use original yoke) at the time I replaced the front rope seals in the oil pan and timing cover and did some other engine work. It was an early FAM from 1963 when my Dad and I replaced the engine (I was 12 at the time). The rubber pad under the mounting yoke was hard and splitting, and the rubber parts are no longer available.
I didn't realize it at the time, but the engine was now lower than before and the crank didn't fit properly. I had to raise the radiator with extra pads under it to raise the crank hole in the shell so I could use the crank, and that threw the hood off (worse than before), and then the hood latches did'nt catch, ...
I am in the process of installing a Touring Grind Camshaft which I won at the last Texas Tour in Nacogdoches, Texas (next one is June 12-15, 2025 in Giddings, Texas hosted by the Lone Star Model A Ford Club).
Anyone reading this is welcome to come!
With the radiator out, it became obvious that the new motor mount left the front of the engine significantly lower than before, causing the crank to need to be higher in front.
See picture - the new springs on left are significantly lower and smaller than the old FAM ones. The FAM springs have rubber dampening bushings inside them which are hard to see but aren't rock hard like the thinner (3/8") rubber bushing that goes under the yoke. I think the large rubber bushing goes under the frame above the large washer (and nut + cotter key - not in photo).
I replaced the pads for the rear FAM at the same time. The new pads came with a pad for the transmission which I added between frame and transmission tower - thinking that's where it belonged and maybe I should have or needed it. Was there one there originally and it got lost? That was 60+ years ago and I don't know.
Thinking of going back to original FAM after making a new rubber bushing (thinner one in picture).
I do not understand why the new stuff is so far off. Have verified (e.g. Service Bulletins) that all new parts were installed correctly).
As the size & length of the new "original" springs (left-most in picture) are visibly less than the old parts. I do not understand how they ever could have supported the engine in the proper location. And yet they did from the factory as we all know.
Advice / suggestions welcome.
