All,
After posting the question and searching for an entirely different subject (searched for date stamp production day) I stumbled across this information regarding patching and strengthening the fenders.
http://modelahouse.com/tech/fender/index.html
Seems like a chronic problem
A question I have, I have a small rose bud that I could use to heat the fender to normalize it? Can someone describe this procedure?
Do the directions of the cracks, there are two, which emanate from a small triangular hole, indicate a directional stress or strain???
Well I guess since you posted those links, I will also tell you that what Bill said above about the fender being in tension is correct. Correct that problem first.
FWIW, the key 'takeaway' to making this repair last is that you must have the reinforcing wire be welded in a different location than where the repair panel is joined to the fender metal. Otherwise the stress riser will cause it to crack where it was fused together.
On a side note, I wish I could remember when that tutorial was first written but I feel certain I originally posted this here at least 15 years ago, ...and maybe as long as 20 years ago. As I recall, these tutorials and those by a few others was the catalyst that caused us to have the Fordbarn Workshops. I can't remember if we had the first one of those in 2006 or '07.Bob definitely had the proper forethought to post it on his website for it to be preserved.
All metals fatigue over time and use. Their are ways to relieve stresses tuch as normalization or shot peeing after weld repairs but sheet metal takes more care to do that and especially if it is thin. It can be done though.
Another important part or relieving stress is to maintain the suspension in top condition. Worn or broken components don't help at all.
“I purchased a set yesterday from Sam at Arizona Model A's, and his comment was that the front fenders are prone to cracking due to the design of the fender.”
There’s a lot of credibility in that statement.. Look around and all external fenders were prone to splitting. However, if fender stress is relieved between the frame, running boards, fender braces and light bar, they should remain split-free longer than any readers currently on this board!
Imho
