Will N
Now that I'm getting a little more practiced and taking her out on the open road, I find that I get a fairly big front end shimmy when I get her over 30 mph. I don't have a speedo, but I think 30 mph is right because once I took my GPS with me to see how fast I was going, and at the 30mph I was going at the time, it did not shimmy. (I do have all the parts for the speedo save for the cable- that's a to-do job.)
I put new roller bearings in over the winter because one of the old ball bearing cups was cracked. The bearings are adjusted correctly. There is no slop in the king pins. The wheel spokes are tight. The tie rod ends are tight, as well as the drag link end. The radius rod ball had some play in it. I installed a fender washer that I cupped with a ball peen hammer and reinstalled the cap. Seems like that took up the play. But I still have the shimmy- it didn't get any better.
The wheels are out of balance. If you jack it up, and spin the wheel, it always stops with the same point of the wheel at the bottom. So I'm surmising that the out of balance wheels are the cause of the shimmy. I've got the original wooden wheels with non-demountable clincher rims. How do you guys deal with balancing these wheels?
