namvetmike
I've rebuilt the tie rod ends but still get a very nasty shimmy at low speeds. Any ideas?
Sent from my iPad using Tapatalk
SHIMMY is almost always caused by slack/looseness in the steering/suspension system.
Wheels on the ground, have someone work the steering wheel firmly back & forth while you lay under it & observe & feel for that looseness. TRUST ME!
Bill Experienced
Bill,Thanks Bill for your wisdom. It's great to keep it simple and that is the beauty of the Model A.
Same here. Pressed out the old bushings, pressed in and reamed the new ones to new king pins. Then checked out tie rod ends, other steering components. Tightening the steering box also helped, but wasn't the primary problem. Got my wobble from 22-27 mph, then smoothed out. Once king pins replaced, all was smooth.For me it was King Pins. Be sure to check them. Not a small repair, but certainly doable.
Ken
