mrtexas
My Les Andrews Mechanics Handbook lists:
Caster 5deg
Toe-in 1/16" +- 1/32
How about camber?? I realize it can only be re-set by bending the axle.
I'm having bad wear on 215 70R16 tires on the front outside edge. I'll have to re-adjust the toe-in as it is currently 1/4". But the Camber looks excessive to me. With a level top to bottom, the bottom of the tire is 5/8-3/4 inch from level tipped in at the bottom. Camber measures +2deg one side and +1.25deg the other side.
Caster 5deg
