LeroyM
I'm trying to put together a puzzle on my front brakes. I have 35 Ford wheels, 32 to 34 Ford spindles, 32 to 36 front axle, 35 rear drums & hubs. I'm looking to change over to hydraulic brakes on the front of my Model A, I've already got the rear brakes covered. Can I simply get a set of front hydraulic backing plates from 39 to 48 and use the 35 rear drums on the front and just change the hubs to 39 to 48 front hubs or is it more to it then that? The goal is to run 35 wire wheels with hydraulic brakes.
I figured since I already have 35 rear drums and running 35 wheels there's no use to change to later style drums if the front and rear drums are the same and will work on 39 to 48 front backing plates with 39 to 48 front hubs.
Has anyone done this? Any help would be appreciated.
Thanks.
Thanks.
