Having trouble with a 1928 Fordor and looking for help/ideas. Car has all new brakes/bearings just done a little over a year ago. If you back out out of the garage and drive back forward slowly there is a loud "groan" from the right front wheel. No noise when in reverse but consistent when moving forward slowly. If you drive faster there is no noise, however the front brake on that side does squeal a bit.
Jacked up the car and tire moves freely forward and reverse. Checked brake adjustment and pretty much perfect. No noise, no catching or anything. Only when the weight of the car is on the tire and driving slowly in forward.
Will pull the tire and front drum off to see if I can figure out what is going on but hoping for ideas that might help send me down the right path and fix this problem. Thank you in advance.
