runmikeyrun
The rubber hose has disintegrated and fluid is leaking out. With application of PB Blaster soaking over a week, what do you think my chances are of the hose fittings actually breaking loose at the wheel cylinder and brake line fitting?
I don’t have the means to pull the wheel where the truck is if something goes awry. It would have to be towed to the shop. Figure it’s worth a shot, right?
