bogdonj
Currently re-restoring our 31 Tudor and working on getting the rims power coated and new Lester tires. Well that's being done I decided to take the brake drums off and check the brakes and clean them up and get them also ready for repaint. When I got finished both sides, I looked at the one drum and the bearing racer? Inside the hub on the racer has a crack in it. (see pic). Can this be easily punched out and replaced with another bearing and the inside racer? I hope I’m using the correct terminology? If so I searched on synders and couldn't find a match to the part I need.
Any advice on this would be great! Currently learning every step of the way.
Justin
Justin
