J jerrytocci Senior Member Jun 8, 2026 #1 Parts are worn and pin is a bit short. Is there a trick to get better performance?
nkaminar Well-known member Jun 8, 2026 #2 New pin, or weld on end and reshape, or add a shim. See https://www.snydersantiqueauto.com/product.htm?pid=977561&cat=41655
Jim/GA Well-known member Jun 8, 2026 #3 I have even found new pins to even be too short. They are the factory correct length, but wear or reproduction parts in other places that are the incorrect dimension result in the pin being too short. I end up using the "pills" on most cars.
