Moodswing83
What do you do with a slightly bent front axle? Is there anyone in the Michigan area that straightens these things? Evaluating cost over replacement.
Thanks,
Gene
Thanks,
Gene
You need 4 Alignment rods, and 4 Alignment cones. I put all rods in at once, run a chalk line from the two end rods, around the out side, and make the two rods in the perch holes just touch on the out side. This will set your bend for the length, and also get all the rods on the top, all in a row, like highline poles.
The last thing is measure between each of a set of rods, ( Top and Bottom 3 spaces) and bend Axel up or down and make both measurments the same, and all that will be left is the Toe In, when you put it back together.
Wa-lua, a perfectly aligned Axel.
Would you be willing to give is those measurements?
Has anybody researched the original Ford print at the Benson Ford Research Center? That would give a definitive answer to angles and possibly other overlooked points of reference.
