SofaKing
I replaced the kingpins and bushings on my 39 pu last December. This morning I had the front jacked-up and noticed that both king pins were loose in the axle and the tapered bolts securing the kingpins were not very tight. I snugged the bolts and the play between the kingpins and axel is gone (for now). I noticed one bolt is now well below flush on the axle.
Is there a standard repair for the axle hole, that installs bushings for instance, to eliminate side-play between the kingpin and axle? Any other suggestions? Thanks
