Hi, Folks;
First post on this forum, and it has to be a question.
Building a speedster out of a '30 frame and '28 cowl. The front axle from the donor chassis was pretty bent, as was the steering rods, so it had a "history".
Rather than mess with it, I picked up a swap meet bare axle, whose holes looked in great shape. Rusty, but no where near as bad as the original.
I just got through sandblasting it, and it looks purdy, but cast into the inside of the beam is small "AA". Does that mean it came out of a truck, or is that just a foundry identifier? If it DID come out of a truck, is that OK for this application?
Also, I started wondering which was front and back! Now that it's all clean it looked the same either way, except when looking really closely viewing from one of the spindle ends I can see a bow to the center section. Very slight. Is that supposed to be there, and if so, does it go toward the front or to the rear? I would imagine there would be something to give the alignment some caster, but I'm not sure how they went about doing that.
Thanks in advance for your help.
