Fresh 59L 270 ci rebuilt Flathead
Eau Claire
wi
Price
$2800 obo
Fresh truck motor 59L rebuilt. All the machine work is done including acid dipping which really cleans up the water jackets, very clean block to start with. Bored 0.100, with 4 cylinder sleeves, acid dipping showed pits we didn't want to chase. The engine has 8ba rods, 4" crank, should be around 270 ci. Build includes the rotating assembly, new valve seats, lifter bores drilled for adjustable lifter, new cam bearings installed, head studs removed. I would include an oil pan, front cover, stock bead blasted heads if desired. No cam or lifters installed, I left that for the next guy. I thought I should save this block since finding one without cracks keeps getting harder. I'll work with you on delivery options, i'd deliver within 100 miles, and i'd deliver to our Fastenal store if you choose that.
I have photos, but I can't figure out how to compress them down to fit this site. contact me and i'll gladly send the photos to you.
